Seb.F
Enthoo Primo - SLI 980Ti
It was November 2011 that I purchased my trusty X79 system. X79-UD5, 3930K, 16GB Corsair 1866MHz DDR3. While there are some fantastic pieces of kit around now (looking at you X99), with the persuasion of others, I've arrived at a decision not to change any of the core components out just yet. Instead I've achieved a solid 4.4GHz clock and will be sticking with it. The Titans however, are going to a new home. To possibly be replaced by, more Titans! These will be of the X variety however. The case is also going, while the 540 is a fantastic case, I think everything is getting a little tight inside there. So we're going big.
So far I have made a few basic purchases for the build:
Enthoo Primo
2 x 3TB Seagate HDDs
TPLink AC1750 Wireless Card
I need to decide on what I'm doing watercooling wise. The Enthoo Primo can fit a decent amount of rads in. I've only had my AlphaCool rads for about 18 months so it seems silly to get rid of them if they are capable. I currently have 2 x 240 rads and 1 x 360. They are all ST30s so single width.
Looking at the Enthoo Primo radiator support it can easily fit those in. But the question is, how do I do it, 360 at top, 240 bottom and front? Or do I scrap one 240 and instead get another 360, maybe a double thickness and stick it up top? Need input here.
Also need a hand on what people thing the best tubing/fluid would be. The previous white tubing seems to go a rather nasty beige after about 10 months which isn't too nice. I was thinking clear tubing and then some sort of coloured (blue? pastel white?) fluid.
First case pic, it's damn big
Enthoo Primo
