Enermax PSUs: any good?
JesseLactin
I need to replace my Enermax 485W PSU with a more powerful once b/c I'm putting a GTX 560 Ti(most likely-for F@H) and XSPC Rasa kit into my Phenom II X4 rig. I'm leaning Enermax b/c their PSU's keep fans on for 60s while off. How is the quality/customer support of Enermax?
emermax are very good mate
you can also try corsair or bequiet psus or even seasonic all thoae psu companies are top notch fella
How is Corsair's customer support/ RMA service? I'm cosidering buying a Force GT SSD form them, and now a PSU(I already some Corsair XSM3 RAM from them).
Enermax is a really good PSU manufacturer. Corsair and Seasonic who make Corsair PSUs are really good as well. Also Corsair is famous for their customer support
Corsair CS is crap tbh i had to spend two hours on the phone with them just to get a replacement part and then they shipped it to the wrong address as well, they just put the country, county and city on the address code and expected it to get to me -.-
Corsair seems to have excellent CS, but they don't seem to reply to thier customers, they just send what you need. Them having BS rebates is most likey true though. There rebate website sucks. I think I'll go with Enermax cuz they keep fans running (I'll be running a 360mm rad in a WC setup), but will they keep a pump running on a molex cable running
I've made very positive experience with Enermax as well as Corsair PSU. biggest difference may be the fact that Enermax acutally manufactures their PSU, Corsair does have several OEM (Channel Well --> HX, Seasonic --> AX up to 850W, Flextronics (AX1200)).
It does NOT keep the case fans going, only its own fan, to cool the PSU, therefore it will not keep a pump running, only the PSU fan.
Cool Guard was what kept case fans running, but Enermax seems to have stopped using that technology. (caused rebooting issues w/ some mobos) All their new PSUs have HeatGuard, which only keeps the PSU's fan running. I think I'll go with Corsair because of that.
