Ok,
Have been interested if overclocking a cpu or buying a better cpu has a noticeable affect on gaming performance.
In particular my favorite game COD4.
Test setup:
E5200 @ stock 2.5ghz
E5200 @ 4.175ghz
8800gts @ stock
8800gts @ 684, 1036
4gb ram
Asus commando mobo.
17" monitor @1280x1024
Test game: COD4 @ 1280x1024 @ max settings.
Results:
FPS recorded using fraps, for 7mins, on crossfire map multiplayer.
E5200@2.5ghz 8800gts stock
Frames: 24238 - Time: 207846ms - Avg: 116.615 - Min: 41 - Max: 236
E5200@2.5ghz 8800gts oc
Frames: 57159 - Time: 420000ms - Avg: 136.093 - Min: 67 - Max: 251
E5200@4.175ghz 8800gts oc
Frames: 80153 - Time: 420000ms - Avg: 190.840 - Min: 69 - Max: 253
Ok, the results speak a thousand words.
Overclocking the graphics card increased the min fps dramatically 63% improvement. The average and the max fps also improved considerably.
With the cpu overclocking, the minimum fps only mimproved by 2 fps, showing that the cpu doesn't bottleneck the min fps. Aswell, the max fps is also only 2fps better, this shows that the gfx card is at its maximum potential.
Whats really impressive is that teh average fps have improved from the stock clocked results with oc card by 55%. This is VERY noticeable in game play, as the motion feels much more fluid.
If you are wanting better fps out of your system, remember that the cpu will always slow the gfx card down a certain degree. Overclocking your cpu or purchacing a more powerful cpu will allow the gfx card to accelerate the frames more easily.
Any comments, for results of your own post away!
Ed
Test setup:
E5200 @ 4.175ghz
8800gts @ stock
8800gts @ 684, 1036
4gb ram
Asus commando mobo.
Results:
Ed
