GoldenbanjoDJ
Hi fellas! Been having some trouble with some old games in Windows 7. Have come to the conclusion that the best (and in fact only) solution to my problems is to dual boot Windows 7 with Windows XP.
I am thinking more along the lines of doing a fresh install of XP on a completely separate SATA HDD and putting this new drive physically next to my Windows 7 SSD in my Coolermaster Haf-X. Technically, then, it is not a 'dual boot' in the classical sense.
I want it so that if I ever want to do a bit of legacy gaming, which won't be all that often, I can simply tap F8 at startup and select the new SATA HDD it is installed on. I have Windows 7 on an SSD and I want the PC to boot to it every time unless I tell it otherwise via the F8 method.
(I know with dual booting, you have to actively press enter over the highlighted boot device when you turn the PC on, and if you don't select within 30 seconds the computer selects the default (first installed) system. I don't want anything like that. Part of the joy in having an SSD is that you can turn your computer on and leave it for a second or two, maybe nip to the toilet for a quick tinkle, and come back and it will be raring to go. I don't want to have to press enter every time, or to wait 30 seconds (which would wouble my boot time) for the system to load Windows 7. The Windows 7 SSD would be labelled in my motherboard BIOS as the priority boot device.)
I'm sure this is all kosher, but:
1. Will this work?
2. Is there any problem with me using a SATA HDD with windows XP? I have heard there may well be.
3. Is there ANYTHING I have overlooked or should be aware of, or is there any advice you could give me?
4. Will this mess anything up or move anything in ANY way?
Thanks for reading my essay!
Love, Dan xxx
1. Will this work?
Love, Dan xxx
