dual 760 vs 1070
It all depends on luck tbh. Anything over 60hz with Vsync hacked off (you can't disable it manually, even if you do it remains on) is a risk. I had it working fine for hours, then when I did the main Mechanist quest it would freeze up when I accessed her terminal (right at the end). In the end I found a video on Youtube showing that you need to access the terminal from the right side. Very odd !
hey,
i have a gigabyte GV-N760OC-4GD REV2.0 . Overclocked nicely to 1316mhz and 6600 on the memory.
I found a used one for roughly 100 bucks and considering this over buying a new 1070, just want a tiny bump as I do most of my gaming on a 27" 1080p monitor at 60hz. (can overclock to 75). Is it a good idea?
See signature for other specs...
im a very casual gamer, but enthusiast enough to overclock a little and play with these kin d of things...my i5-4690K i still clocked at 4690 stable with good temps, below 80 usually in spring/autumn, but can get up to 86 in summer though...
so basically, i can afford both a 1070 or 1080, but im not sure if i want to spend that money yet.
100euro a 760? 100% no !
50-60 euro maybe
