Driver help needed
sacha35
Hi guys hope that you might be able to help me out a bit, i am trying to run 3Dmark01 and have experimented with different drivers, what i have found is that if i use the 8400 drivers the car test has a boost in frames but the nature test drops frames, if i use the 7500 drivers the car test drops in frames but the nature test gets a boost, is there any way i can mix these drivers so that i get a boost in both of these tests, any help you guys can give would be most appreciated and help me get this last test under my belt for the team.
sacha
