Does this gpu need RMA?
Chris_taylor
Hey guys, got a Evga Gtx 780 classified about a week or so ago and have noticed a weird pitched noise coming from my gpu when it throttled up past 45% fan speed and then when past that point just air noise then when it throttles down it makes the same weird whirring pitched noise at 44-45% fan speed. Extremely annoying, at it sits at that fanspeed a bit. Is this an RMA issue?
Any info would be great on this matter
Do you, by any means, mean coil whine?
If so, sometimes this can be fixed by letting the card run under maximum load for a while. If this doesn't help there's not much I can do, and I believe that coil whine is seen as a good reason to RMA a product.
Try setting up a custom fan profile in afterburner or similar so you skip the 44/45% fan speed...
I dont think it would be accepted for RMA....
No this is not coil whine I think.
Try to do as FTLN said and see if it works. If the sound only appears for a second or so then I think you're going to have to live with it.
Yeah, it's just at I'd say 43-46% fan speed, like a chirping noise :/
As for FTLN, do I just set the fan speed at a constant 47% upwards? Is that what you mean?
No, just said that when it as at X temp/load it can go up till 42%, then the next degree it ramps up to 47%. That was it will skip the 43-46% area in which case you won't (or barely) be annoyed by the noise.
