Layer Cakes
Note: wasn't sure where to put this as it's not a build log for a rig. Please correct me if i've chosen poorly
So, I wanted a nice wireless setup for TV gaming from my bed. Obvious choice is Corsair's new K63 lapboard and keyboard but at over £200 not including a mouse, this was just way too far out of budget. Plus, it's only blue LEDs..
So I picked up this bargain £35 wireless, mechanical RGB keyboard called the 'Drevo Calibur'.
Next was a trip to the local hardware store for some wood and I got to work
I added the channel at the top so I can charge the keyboard while it's on the board if need's be... And it was easier to cut that way :lol:
It fits!
I'm going for a sort of two layer design so the keyboard will will sit flush and to make sure it's not going to flex. Might end up being a bit heavy, but it doesn't matter too much as i'm not going to be taking it around with me or anything.
I'm waiting for the wood glue joining the top and bottom layer to dry, then i'll be painting it tomorrow, so stay tuned for the finished piece in the next couple of days.
~~ Lucy
It fits!
~~ Lucy
