Distilled or DeIonized Water with KillCoil, Biocide or what?
It's been nearly a year since i did my loop(pics are in my sig) and i think its time for a change.
This initial loop that i have now, i used 1 and a half XSPC EC6 Clear, i like clear coolant and this has had no problem at all.
Now this time round i dont want to pay £9 odd for 1Litre of coolant. Instead i want to use something cheaper and this is where im running into some problems.
Which coolant/water to use for a watercooling loop - Distilled or DeIonized?
Also, what other things do i need to add within the loop if using distilled or deionized water and not a premixed coolant like XSPC's EC6 - Killcoil or Biocide?
Will the silver killcoil react/corrode to anything in my loop at all? I have the following components:
EK-Supremacy Clear Nickel Plexi
XSPC Razer Titan Block w/ Backplate
Alphacool UT 360
Alphacool UT 240
Phobya Balancer 150 Silver/Nickel
Alphacool D5 Pump
XSPC D5 Top
XSPC Assorted Fittings
Thanks in advanced :)
I recommend more clear coolant. You'd need to buy killcoil/additives with water anyway so the price difference won't be much.
Deionized is less pure than distilled, you can pick it up at halfords etc. I use deionized for flushing and short stints in a loop.
Distilled is hard to come by in the UK, might have to try a chemist, or failing that pick up mayhems ultra pure H2O (at that price you may as well get clear coolant).
In all honesty why cut corners for cash when it comes to water? I'd get the same as you had last time if it worked.
If it aint broke mate...
