Hi all,
Just wondering if anyone can shed some light onto what will be causing this issue, I'm talking from the point of a fresh install of an OS:
I'm using a 22" UMC TV and GTX 560ti linked via HDMI cable.
When I first connect up my monitor the display is bigger than the physical screen (almost asif it's zoomed in). Usually I get around this by using the Nvidia tool to re-size the display to what I want. However, I'm wanting to start tinkering with Linux and I'm unable to get the Nvidia tool to resize it rendering my 22" screen pretty much useless.
This issue is apparent whatever resolution I use so I'm certain that's not the issue here. I've read on a couple of threads that it may be a setting on the TV but I've not found any setting that affects this. I also have a secondary 15" monitor (VGA) which has none of these issues.
Any help/ ideas would be greatly appreciated
If further info is needed just ask.
Thanks
Thanks
