Display issues
iv kept an eye on temps and even when I start up the pc it does the display has encountered an error and fixed itself
one card is at 50c and one is at 34c with fans at 100 percenty
and another question if I may is it a bad thing to run fans at 100 percent all the time because I had it set to auto and was only going to 33 percent and now I have put them up to 100 and everything has become stable
Thats strange....
What max temps do you get with auto fan.
Also, next time instead of triple posting, just you the edit button
What drivers does GPU-Z say you're running. Just to make sure that the drivers aren't an issue. Personally I think its a hardware issue but better safe than sorry.
catalyst 14.4 ok so on auto at 38% fan speed card one is at 61.0c and card 2 is at 37.0c and stable atm soo kind of confused
I've had that issue with a dodgy Display Port cable. I swapped it out and all was fine, That was after doing everything else that has been advised first, remove driver, use, DDD in safe mode, try each card on it's own in top slot. It's just a case of not panicking and being methodical in your testing procedure.
Its a driver issue. Not a hardware issue. Brother had the same internet explorer error from CCC on 14.4.
Though you should all know already its a driver issue since the issue appeared after he updated them... as sub said.
Its a very confusing fix. Been a while since i fixed it.
Could try 14.7 if your on Win 8.1, I had a similar issue to OP in the past, but after a clean install of 14.7 my system is completely stable again.
