paulstung
I'm starting to look for a pair of blocks for my pair of R9 290's, I've got it narrowed down to either the EK-FC R9-290X Full Cover Water Block - Acetal+Nickel, with the matching back plate, and the appropriate bridge. With this option it will look right at home in my black and white build, with the odd touch of silver.
Then there is the qua Computer Kryographics for R9 290/290X, Nickel Plated - Black Edition, with the active back plate, and appropriate bridge. With this option it adds a bit more silver into the mix.
I'm focusing more on looks, as blocks don't have a hole lot of difference in performance, unless there is something I'm missing out of these 2. What do you think guys. So far there is only a touch of silver, that's a 3rd cable sleave colour, the res bracket, and ant cyclone, and the rad fittings.
