Did CM V6GT fit on Biostar MCP6P M2+ mobo?
delam hadz
hi, I have this huge question I have a motherboard biostar mcp6p m2+ with a PhenomII X4 925 Buuuut bought it without cooler and i'm looking for one to build the damn machine then i saw the CoolerMaster V6GT check the dimensions and that but without all the dimension (talkin about the pipes) i guess it wouldnt fit or will be thighted, if anyone knows if fits on the mobo your help will be so much appreciated or if you know another good cooler i hear recommendations , i was thought on the hyper n520 and the gemin II S524 but dont know i like the v6 gt first, well thanks in advance and have a nice day
[font=arial, sans-serif]case . [/font]http://www.tigerdire...7810&CatId=1842
[font=arial, sans-serif]mobo. [/font]http://www.biostar.c...on.php?S_ID=370
cooler V6GT. http://www.coolermas...product_id=6668
Looks to me like it will fit, it will be close, but I say it should fit... cooler is 164mm tall case is 190.5mm wide...
generally take off 20mm for motherboard, backplate, standoffs and headroom so 170mm of clearance...
so, rough estimate says you should be good to go.
Goldskis45 thanks for your answer, but im worried about the video heatsink just down the processor socket and the ram slot just 20 mm right the cpu socket and the video is 45 mm down the procesor, here are 2 things im worried about the first, 1 is the heat pipes i m gonna be really disapointed if all fits except the heatpipes and 2 i dont care if it blocks the rams slot when the ram are inserted , im not gonna be changing the ram in a while
well, if you have the heat pipes pointing north to south on the motherboard you will be fine, just a quick Google images search shows thats a really short heat sink, you will be fine, as for the ram, as long as its lower profile, and doesn't have huge heat spreaders you are fine...
that was the reason about this, i see pics and when i see the heatpipes i get worried, but well, im gonna take your word and get that v6 gt
thakyou so much man
Gah, I overreacted.
However, you do have a hard case convincing me that someone would buy something that looks like this and not overclocking. And overclocking without touching VCore.
Just because something looks good doesn't mean it preforms better than something bland?
My home computer looks like it should be a beast but its running an original core duo.
The rig I just finished for work looks like a grey box with a bunch cables hooked into the wall but It has 8 individual processors and 10 graphics cards in it...
Aesthetics and performance have nothing to do with each other...
anyway... enough of bumping and getting this off topic from the OP.
jajajajaaja yes i was thinking to do a little OC , that will be the firs time doing it, but get worried about the VRM after reading that post ,anyway i ended buying the hyper plus 212 (that was my own bday present by the way
) that barely fits on that cabinet, now the problem is that i finally assemble the pc with the phenom 2 x4 925 the mcp6p m2+ mobo, and a psu of 425 watt and thecooler mentioned above but it just on like 2 minutes and then freezes, any suggestions?
