Arcnor
Before I start, I'd just like to say that I am never rolling my own PC again. Ever. This has been pure hell.
Okay, so a few days after I finished my PC, everything seems to be working okay, but I started having a weird display error when quitting out of a Steam game back to the Windows desktop. My display would go one solid colour. Not a BSOD, just blank. Could only rectify the problem by doing a hard reset. I thought it was a Steam issue at first, and gave Valve some crap about it.
Then the same issue started happening somewhat randomly in a really old game (Fable: The Lost Chapters to be exact). It seemed to be a driver issue, maybe (specifically a TDR error, except my system would never recover).
Then it started happening when web browsing using Google Chrome, again randomly.
I also had instability (BSODs) while playing Tropico 4.
Now it's happened after I've completely wiped my SSD and was in the process of re-installing Windows 7 (can't really be a software conflict if there's no software, right?). It occurred right at the moment I was updating Windows and it said it was installing some low-level NVidia driver (not the driver from the website, just something that was included in the Windows update).
So I turfed everything even remotely resembling an overclock. Still got the error.
Took my rig to a local repair shop ("local" meaning "an hour's drive away"), and they said they could get the video card to crash consistently and recommended an RMA. I have RMA'd my GPU. EVGA are baffled -- said they didn't find anything wrong with the card. Second card had the same error, almost immediately. RMA'ing that too, just in case. Repair shop are equally baffled -- they said their tests pointed to a GPU defect. They suggested the problem might instead be the motherboard.
RMA'ing motherboard -- work in progress.
Tested RAM with Memtest86+ -- no errors, but I never ran it for 24 hours straight. Still, the fact that the error could be counted on to occur after quitting out of a game or a graphics benchmark like Unigine Valley makes me wonder if it's RAM. Not exactly a "random" event, there.
Power supply voltage readings (at least through software) never vary or drop on any rail, and 650W should be plenty for my system.
Does anyone have any further ideas, or do I just have to go down the list and replace every component one at a time until I hit the problem, and hope that it's just not some weird case where my particular hardware combination doesn't want to play nicely together? I use the HDMI port on the GPU, if that makes a difference, although I hardly think it'd be a conflict between audio drivers like some people experience, mostly because the error occurred in my re-install process before any such drivers were present.
Please, please, please OC3D, this is urgent. Does anyone have any further suggestions for what I can do?
