Delidded Ryzen 9 9950X3D runs 23 degrees cooler than stock
WYP
News Guru
Ryzen 9 9950X3D delidding can yield 23 degrees lower thermals, or 9% more performance.​
Read more about der8auer delidding AMD's Ryzen 9 9950X3D CPU.
TBH I've always seen this sort of stuff as quackery.
The delid tool costs a small fortune and you would only use it once. You then need a direct to die wb which sounds expensive.
All this for 9% more performance.
Which will end up being insignificant.
