de_dust HD screenies and my New Spray
Yeah it does look a little large, I use cl_crosshairscale 3000. Thanks Jim :worship: I love the HDR screenshot too Kemp. HDR can be a bit funny at times, I haven't found the effect at all problematic with CS:S, but I remember a few spots in FarCry that looked a little unrealistic (typical I 'spose, due to it's relative infancy). All in all though it's sweet
Yeah 3000 is what i use too. Makes it almost like a laser dot..nice and easy to point at heads ;)
Sorry to go a little offtopic here, but what colour do you keep the crosshair at XMS? Is yours kept on white all the time Kemp or dependant on the map?
I keep mine at light blue, as i find that suitable for most maps. However, i'm toying with the idea of turning the crosshair off, and using a cd pen to make a dot on the screen.
This way i can easily shoot with the awp/scout unzoomed, and size/colour wont be an issue.
Sweet, a permanent marker would be cool!!! When you wanna remove it a little methylated spirits will do the trick. You still use a CRT right Jim? I dunno how the marker would go coming off the front of your Dell though Kemp, prolly wise leaving it be :D
Yeah glass screen ftw!
I've used the marker trick in the past for a laugh, and one of those screen wipes took it straight off :)
i use to use a peice of masking tape and just stick it in the middle for sniping, but mine is set to like cl_crosshairsize 5000 its like a dot.
