But this means if my cpu gets to hot it wont turn the fans up! does the mainboard shut down the pc by going over temperature?
But how can you control it? its a 3 pin on the fan and 4 pin on the mb... even if you cange some settings in the FanExpert you are not changing anything... or do you?
ok I'm back... works geat, with prime running it did not went over 47 °C (with U.N.L.A.)
@SieB: I'm sorry for you but it does NOT conrtol anything!!! I can even see the proof in your screenshot, if at the numbers for rpm you can see that they do change just a bit... and random not going up by increasing more foltage. So sad face for you but your D14 is running the same speed and noise all the time![]()
^^ of cause you here the difference... you have pluged it into a chassis Fannot the cpu one... so if you pluged it into the cpu 4 pin header and than change the speed of the case fans it makes a difference... but not for the d14![]()
