mb67
Hello one and all. I'm getting the necessary parts together for my first ever custom loop computer, and I wanted some thoughts on a loop layout.
Any assistance would be greatly appreciated.
But first, a little background:
I wanted to be a little 'different' in that I bought a case that is not very well known here in the US - The Jonsbo UMX4. It's a rather small ATX case with two gorgeous tempered glass panels on it. The PSU sits up front with some room underneath for cables to stack or possible a small pump/res, which is what I want to do. Also, there is room for a pair of 120 fans at the bottom. Since the case is not in the EKWB configurator I used one that was close in specs and it gave me a 240 Rad up top, and a 120 Rad at the back. The CPU will be the Ryzen 7 1800X, the GPU's 2 x GTX 1080Ti's FE, on the ASUS Crosshair VI Hero X370 board.
I've already got the CPU/GPU's and the corresponding blocks, as well as the board and case, so I'm committed to doing this. I just need some help on the layout.
Two questions: 1) will the 120+240 Rads be enough? 2) will the following layout be sufficient?
This is the flow chart I came up with:
From the pump/res, to the GPU's, to the 120 Rad, to the CPU, to the 240 Rad, back to the pump/res.
A pic of what I conceptualized:
A stock picture of the case interior:
