Highland3r
Finally sold the last of my AMD kit (feel awful knowing LDBHE 0601 X2 is gonna run stock for the rest of its life :'() and in the process of migrating 24/7 rig over to Core 2 (E6300, AB9, Crucial, etc...)
The prices of DDR2 at the mo are frankly shocking, 240 quid for 2gb GSkill HZ? Erm no thanks!
So, decided to plump for something a little "cheaper", after seeing the results from the Crucial, and knowing how good D9 xxx IC's are couldn't resist a kit. 186 quid inc shipping from crucial direct (thats including a coupon code, PM me if you want it) seemed like a bargain!
The ram's rated to 333 mhz @ 3,3,3,8 timings (although SPD shows Cas5 for some reason!). It booted fine at these speeds in the AB9 but stock isn't where this rams going to run. The below are just quick "stick it in and run" tests. The AB9 doesnt have a huge range of timings available in bios, but seems to run the memory pretty agressively (*sp) based off memset.
First attempt was 400 FSB 3,3,3,8 2.2v. Instant no boot. Damn.
2nd attempt was 400FSB 4,4,4,8 2.1v, booted and into windows fine.
3rd attempt was 443 FSB 4,4,4,8 2.1v. Again booted to windows and passed 100% windows memtest.
4th attempt, 443FSB 4,4,3,8 2.1v. This is where it's currently sat running windows memtest again.
Note, I'm using memory dividers/chipset straps to increase the memory speed due to the board not having working multi controls (although dropping multi would max the chipset anyway so wouldnt gain a thing) there maybe different results once the 6300 goes in and things are run 1:1.
Will do some other testing over the course of the day but so far the ram doesnt look too bad at all.
Also note, via DMM the vDimm is showing as 1.99v need to verify this but if its correct then very nice ram indeed
