FarFarAway
w00tage!! :worship: :wavey: My Coolermaster crossflow fan is being sent to me today!!
All the reviews I've read say that it lowers all the temps in your system by about 2-3*C so I'm looking forward to it!
Specs:
Cross flow fan is a special designed blower for CM Stacker which can provide superior air flow and blows cold air directly to the key components onto your motherboard. In addition, with its adjustable fan speed controller, it allows you to have a totally control of performance and silence.
Specs:
Application for CM Stacker
Dimensions 50×50×336mm
Weight 400g
Voltage DC12V
Start Voltage 5V
Current 0.24amp
(4speeds) OFF 0 r.p.m
LOW 1400 r.p.m ( 6.5 V )
MIDDLE 1800 r.p.m ( 8.5 V )
HIGH 2500 r.p.m ( 12 V )
Noise Level 0 dB (OFF)
22 dB (LOW)
30 dB (MIDDLE)
38 dB (HIGH)
Airflow 0 CFM - 0 r.p.m
25 CFM - 1400 r.p.m
32 CFM - 1800 r.p.m
46 CFM - 2500 r.p.m
Pressure 2.0mmH20
Life Expectance 30,000 hrs
Bearing Type Ball Bearing
Note NOT compatible with extended motherboard
Specs:
Specs:
Weight 400g
Voltage DC12V
Start Voltage 5V
Current 0.24amp
22 dB (LOW)
30 dB (MIDDLE)
38 dB (HIGH)
25 CFM - 1400 r.p.m
32 CFM - 1800 r.p.m
46 CFM - 2500 r.p.m
Pressure 2.0mmH20
