Hi there,
New member here, so go easy on me.
I'm in the process of building a new computer. For CPU cooling I have the Corsair H100i and replaced the stock fans with a pair of Noctua NF-F12 fans. Typically they would be connected to the H100i's pump. However my motherboard, Gigabyte Z87X-D3H, has an additional fan header labelled CPU_OPT. After flicking through the motherboard user guide, it shows that using this header gives you access to a set of different profiles in the BIOS (one called "silent mode" which sounds perfect). It also would facilitate better cable management as it would be one less cable hanging from the pump.
So I guess my questions are...
1. Has anyone had experience of using the CPU_OPT header on Gigabyte boards?
2. Would the H100i freak out if I use CPU_OPT rather than the pump's built in controller?
