SieB
Can anyone tell me if the temp for core 3 is ok?
I have noticed that the temp for core 3 is quite a bit higher than the other cores, I know that there will always be a few degrees between them not matter what but I was wondering if the difference is higher than it should be.
I thought maybe it was because I didn't apply my thermal paste properly but I have re-applied it several times and it's always the same with that one core. Everything runs fine thou and it's not causing any problems, using the crappy stock Intel cooler BTW.
EDIT: Strange, I just downloaded Real Temp and Core Temp to see if it's just Cupid and the temps are different on all three, which one do I trust?
