CPU Q9400 Overclocking Process
buddyboy
Hello. Plz Help me Overclock my PC. I never do It, but I wanna try. Here are My Specifications:
CPU Type: QuadCore Intel Core 2 Quad Q9400, 2666 MHz (8 x 333)
Motherboard Name: MSI P45-8D (MS-7532) (3 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, 4 DDR3 DIMM, Audio, Gigabit LAN)
Motherboard Chipset: Intel Eaglelake P45
System Memory: 4096 (2*2) MB (DDR3-1333 DDR3 SDRAM) OCZ XTC Platinum OCZ3P16002G (7-7-7-20 @ 666 MHz) (6-6-6-18 @ 571 MHz) (5-5-5-15 @ 476 MHz)
BIOS Type: AMI (09/18/08)
Video Adapter: ATI Radeon HD 4870 (RV770)
Thx in Advance for Any Help!
You want check with OCZ tech support to get RAM timing and correct Voltages for your RAM. Also, you want contact tech supports from Intel and MSI. "How to Tweak" settings your CPU and Motherboard.
Good luck
