KineticMeercat
Hi, I need help deciding which would be a better choice. A New motherboard in the £130-150 Price range,a 2500k or 2600k and a NZXT havik CPU Cooler. At the moment I have a AMD Phenom II 1035t 2.6Ghz
with an OEM 880g Motherboard, Or should I get a new GPU like a GTX 580, Another GTX 560 for SLi or an AMD 7950.
Space is not a problem I have an NZXT Phantom Case.
I think the GPU will most likely Bottleneck if I get a high GPU with my current CPU though. Help me!
Also will I need another copy of Windows 7 if I upgrade my CPU and Motherboard or can I use the Windows 7 install that came with my PC originally when I bought it?
UPDATE - So with all of your advice I decided to buy a:
I7 2600k OEM
Gigabyte UD3H Gen 3 (PCI-E 3 Version)
NZXT Havik Cooler (I Chose this because it will match the colour scheme of NZXT Phantom).
I Am going to overclock the CPU To 4.2Ghz+ aswell. thanks for your help guys
I7 2600k OEM
