Noob help time
I Currently have the rear fan plugged into the CPU fan on the motherboard as it was saying CPU fan error when i booted up (unless i can stop this happening)
But The fan isnt PWM and i cant figure out how to adjust the Voltage because its going max rpm atm. If i Disabled CPU Q fan control in the Bios would i then be able to just unplug it and use it in my Fan Controller? which is what i want to do.
Ive tried SpeedFan but i dont know how it works doesnt seem to do anything, and Fan xpert in Ai suite wont do it either.
its a P8P67.
its a P8P67.
