CPU cooler that will fit in Coolermaster Case
if its 120mm exhaust most coolers will fit hayley,measure the distance from your board to the edge of the case and then look at the cooler heights,,,,, pretty simple tbh
I have put the stock cooler on that came with my I7 980x for now, to stop the vibration
Temps are a bit high though, going all over the place 65-75 degrees at the mo
