CPU and Artic Silver
mutantaxe
I used to use artic silver for heatsinks and Corsair Water cooling for CPU's. Lately I have just used the pads that came with the Heatsink or Corsair 115 ( I think )
Now back then you would use something like a credit card to spread the artic silver very thinly over the CPU. Now I see on some vids they just squeeze a few drops of whatever they are using in the middle and mount the heatsink or watercooling block:confused:
Was it overkill to do it that way ? Of course you had to use Isopropyl alcohol to clean the top of the CPU and cooling blocks first.
Do people still remove the cooling pad that comes with the products ? And how do they apply the "whatever you use these days " ?
You can use the pressure method or the spread. I still spread on larger dies and the pea on small dies.
Arctic silver is a bad move now where its conductive. MX4 is the go-to for me paste wise.
just watched a vid ( checking out Asorus m/b) and he put a fair bit in the centre of a 7820X and used a plastic little "fork" to spread it all over...he actually mentioned you and the person who found heat problems with 299 m/b's when o/clocking........
anyway will chuck out the Artic silver and get the MX
