Cosmos II Build
skadoosher
My first build let me know what you think??
Intel 3770k 4.5ghz
ASUS Z77 Sabertooth
Corsair Vengence 32gb 1866mhz
Corsair AX850
Coolermaster Cosmos II
Intel 510 120gb ssd
WD Caviar blue 250gb X2
Galaxy GTX670 GC 4gb (coming soon)
Corsair H100i
You will have to excuse the camera quality but here you go.....
It looks nice dude. Cable management at the back is a bit dire, but I guess you can't see it anyway.
Also, it would look better if you hid the LED strip somewhere at the top.
I really don't like the positioning of that led strip..
Other wise looks good, although I can't help but feel it would look a lot better with a custom watercooling setup
i agree... cant afford that now though... that is the reason i bought the case though....
Looks good. I look forward to seeing it with the 670 in :)
me too:)
unfortunately with the size of the case most of the cables have to be routed directly to their location or it would be tidier trust me... i spent hours getting it that far.... NIGHTMARE!!! and as for the led it is just a cheapo one for temp soon i will get some thin strips. that one is an led tube soooo.....
No worries. Just a tip for the next time you reply to more than one post: Use the multi-quote button and hit Reply (The multi-quote button is in between the Quote and Speech bubble buttons)
what made you spend you money on a ram cooler and such and expensive case, i love the build but i would have prioritized some things more than others.
Is this better???
Oh and it is because i plan to use the case for a long time and it is a great case for expanding later on with a custom loop for instance. and the ram cooler was like 10 bucks soooo.....
Nice setup! I wouldn't worry about lights right now honestly. There are some companies that make window panels for this case that you can buy and literally swap out the door for one with a window or a full acrylic door panel if you wish but if you're not doing either than I wouldn't worry about lights right now. Wiring is pretty tidy in the front. How it looks in the back is up to you really cause no one is going to see it so as long as you're not tightening the cables too much you're fine. Again, nice setup!
yeah cable management at the back could do with some work, also the led strip needs hiding maybe at the top. Maybe turning the radiator the other way so the tubing isnt like that (cant explain it but i would just change the way it is) but otherwise is looks fantastic really clean slick look i like your style ;) once the gpu is in then we will see if there is anything more to say :P can not wait!
Where can i find the side pannel??? i thought i was going to have to make one!!!!!
i did end up putting it on top and it looks better thx....
Ita acually dosent make any noise.... it also drops my ram temps by about 5c.... and it looks kinda cool in my opinion... oh and it was only like 10 bucks. :lol:
I would never put that thing into my rig even if they give me this for free...
But well in the end of the day is your rig and you gonna make a last choice, I'm just saying that it looks sh*t:) Does your ram gets hot at all? What program are you using to monitor it? And if you really want some more air on your ram, just swap back exhaust fan into intake and job done, much better than with silly ram cooler:D
