Corsair Sleeved Modular PSU Cables with SeaSonic PSU
VeryInsane
Hey everyone!
I've been looking into cable sleeving and after seeing how tedious the task is I decided not to do it myself. (Or atleast for this build hehe)
I was wondering If any of these kits:
http://www.corsair.com/en/power-supply-units/psu-accessories.html
Would work with this SeaSonic PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
I already own the PSU so there's no flexibility there :P
Or If anyone else could find another one like the Corsair one to work with my SeaSonic that would be awesome.
Thanks!
Hey everyone!
Thanks!
According to a review of the PSU on the Newegg site you linked, no they don't.
You could try bitfenix extensions?
Extensions..
Is it not the actual PSU cable, but rather actually an extension?
And how am I to know which ones to get.
They're all spread out. So many of them. I looked at the BitFenix ones and I don't know which ones are good for a PSU.
......... I don't know which ones are good for a PSU.
you are only using an extension on the cables needed.
24-pin motherboard power
8-pin EPS motherboard power
GPU (6-pin or 8-pin depends on what video card)
Molex is using molex power
SATA is for SATA power
SATA data cable for connecting SATA drive to motherboard..
airdeano
airdeano
Well I want the actual cables that will go into the PSU for the X750 not extensions.
there is not a known kit for the seasonic brand of power supplies.
you'll either have to make them yourself (or contract someone else) or use
extensions.
you don't have a lot of options for that specific PSU.
airdeano
well I'd check seasonics page for them if there are none listed then unfortunately none exist. You'll have to do it yourself or pay someone to do it.
nope generic and modular cables are not around. As each manufacturer makes things differently. Since no standard exists for them I doubt there ever will be generics.
well for the easy ones..
a 24-pin
an 8-pin EPS
your video card prolly has some connections
using any SATA power or Molex power?
(as i perscribed in post #4)
and your done...
airdeano
How can someone honestly ask what they neeed.... Surely you understand you need to work out what you need lol!!!
Oh btw the NZXT cables are terrible get Bitfenix
I use the bitfenix extensions in my rig (see pics in sig if you wanna look) they're really great, highly recommend them!
