>>>>>>>>>>>>>>>>>>FIXED<<<<<<<<<<<<<<<<<<
so guys i just installed a new AX760i into my system, and i have the corsair link installed, pluged into the internal usb header, and into the PSU, the green light is on the usb dongle thingy inside the case, and with the corsair link software i can monitor the cpu temps, fan speeds gpu info exc exc....but i can not monitor any information about the power supply! no information about psu temps, or power useage or anything. no options to be found about a power supply at all.....anyone have any information?
so i unpluged the internal usb header from usb2 and pluged it into usb1. problem fixed. i didnt want to use usb1 because it is a high power (quick charge) plug on my gigabyte Z68X UD3 board designed for quick charging phones and what not......i dont use it because my 550D has usb3 in front. so i guess if anyone else has this problem, change the usb port inside
