Corsair launches their new 570X RGB Mirror Black Glass Chassis
To be honest THIS should have been out from the start instead of the other 570X's, Seriously how much extra development time would they have needed to put simple things such as an RGB logo, Vertical GPU mount, PSU shroud end cover and top end 280mm rad support ?
I'm betting they had this waiting in the wings round about the time they launched the 570X and held back so people who were annoyed with the first 570X may end up buying this one.
That glass ruins it. Picture sure makes it look ugly.
Need to see it in person but it's the same as a 570x so I wouldn't touch it.
I really like this one more than the original. Though i really don't like this Corsair's chassis. If I was to buy it i would mod the Hell out of it.
I'm trying to like it, but I just can't. Thing is, I can't put my finger on it, what is annoying me. Maybe its the flash from each RGB light, but I suppose I would need to see it in person.
stock 570x was ok, but nothing special. Seemed like it was designed for looks over performance. Guess airflow is kinda poop compared to others.
I really like it because it is all glass. And for me genuine enthusiast builds are all about the details. Hiding half of your build isn't enthusiastic at all. Yes you can have a neat build, but for proper ones you need to see the inner workings. Every piece of cable, every connector, everything lined up to perfection.
I really need to give a shout to manufacturers. Especially to Corsair, because i know they will be reading this. Pardon my French but, WTF are you doing? You release beautiful white PSUs and your every case has riveted PSU shroud... Yes i can see the point of PSU shrouds on low end builds when you would use some PSU, and extensions to hide ugly cables, so you have it to tighten your build. But you sell beautiful expensive PSUs, and beautiful expensive custom braided cables, and every case you make is designed to hide that beauty. Really complete and utter fail. On epic proportion.
People mod their back panels with glass so they can show off their cables, and you make full glass case with every intention to hide the cables. Yes i understand that you need to follow some trends, but at least give an option to remove it, and employ someone who has actually built some PCs to approve things. Not accountants. You can't even fit your own products in your cases.
