Corsair hx850 watts problem
IIHeadBlasterII
My pc spec AMD1090t-asus C5F_1703bios-sphire7770vprox-6gbram-x2 1tb WDgreencaver x3 140mm fans
5 days Ago i buy new HX850w for OC i i try to oc my CPU but no stable,on only!!!3.7ghz i:huh: instantly i see on bios violtage monitor isee +12v output only 11.944 ?? i cant dispointed this iagain restart but same on UP,DOWN voltage i start windows i see this i puzzled i try all posible trys like*(low loltage no OC CPU,with small GF610,1hdd,all ect disconnected i try all :( plse hellp me ther is pic....
11.944 is normal. It's within measurement uncertainty limits.
Please refer to one of the many overclocking guides on the internet, the 11.944V your +12 rail delivers is within norms.
Take software and bios reading of voltage with a grain of salt because they are not too accurate. If you want to see the real voltage you need to use a multimeter.
but i cant stable on 3.8ghz 1.43v is no high with fsb219 2667HT,NB my older PSu is stable on it it only 450w it normal psu :mellow: 1 minut plse i am Good oc guy but i dont know this problem because ther is no good enginers in fucking india BUt thk :) to share you IDEa
I'm not saying there isn't a problem, but it won't be that your 12V rail appears to be slightly below average. But I have to say, that I don't have any experience overclocking AMD processors via FSB clock...
What he says.
Also 11.994V is fine, assuming it is the true value, the limit for the ATX spec is 11.4V or a 5% tolerance.
