Corsair H70 or Hyper Cooler Master N520???
sweetalice79
i currently have a Hyper Cooler Master N520. i am wondering if the Corsair Hydro Series H70 would cool better. i am hoping i putting this in the right form to ask this question.
Alice
The H70 would be better but so would the noctua u12p for alot less than the H70, you could also look at the nh-d14 if you have the money for the H70 as its cheaper than the H70 and it mullers the H70, U12P and N520 by a long shot, if your not planning on overclocking your cpu the u12p would work nicely to silence your set up and give you better temps than your current N520.
TL;DR dont get the h70 if your going to overclock get the nh-d14 if it fits, if your not going to overclock or are only going for a small overclock the u12p would be better than the h70 for noise level and temp reduction over your current cooler
NH-D14 (Just make sure it fits) > H70 or u12p (u12p if the hnd14 wont fit) > your current n520.
the reason i was looking at h70 was its what they used in the maingear shift pc's. my case is a modified sift case. so was debating if i should upgrade my cpu cooler. im not in to over clocking but want get best cooling i can, pc gets hot. i figured maingear might have the idea with the h50 and i would upgrade to h70.
run a AMD Phenom II X4 965 Black Edition with dual nVIDIA GTX 280's on a MSI NF980-G65. the boared is fried but hoping sl will aprove rma if not im not shure what ill get but looking at the MSI 870A Fuzion Power Edition. im open to ideas on am boards though but this post is about looking to see if i should upgrade my cooling.
Alice
dident it get answerd in yer other thread.
the H70 aint good
yes my other question did get ansered. i was mainly wanting opions on cpu coolers in this one. i thinl ill keep my exising one reading this review or get the nh-d14. just wonder if it would fit in my maingear shift case.
Alice
