alienware
Banned
Big isn't it? Crikey, I just had to do a super duper cowboy deluxe on my second HS fan to clear for the memory
Thankfully the Noctuas allow for it, you can move the fan clips up and clip the fan on slightly raised..
This has got me thinking though.. How much OC will this stuff take? I would like to raise my FSB aswell as using the multi but I confess to knowing absolutely zilcho about ram overclocking.
It's 800mhz XMS2 if that helps.
Also, a massive thanks to Sean. Very very kind of you sir I doff my cap
