Corsair braided cables, need some opinions!
NRG!
Hi,
Sorry if this is in the wrong place, wasn't sure.
I want the braided cable kit but I'm not sure which colour to go for. This pic is very good because the build has a very blue theme overall. (the yellow on the gpus will be gone soon, as will the orangeyred 'AX' on the psu).
With the amount of blue already in there I don't want blue cables.
So I'm stuck between black and white. :/ Black will keep the stealthy look, however I may be switching out my coolant for pastel black soon.
White would look good but maybe out of place?
Gah I can't decide. Persuade me.
Oh yeah, ignore the mess. I had to shove this together sharpish during my assignments. Just finished my exams for the year so I can finally finish this rig now.
Also.. That dominator looks a little off colour o_0.
Blue + white custom sleeved cables would look amazing in there - I think you need something to pop out from all the black. Have you thought about doing the sleeving yourself? Even if you just did the 24pin and the 8pin gpu cables it would look really nice.
Otherwise, I think it might be worth looking at white coolant and white cables. If the only white bit in the whole build are the cables, it might look a little out of place.
Thanks for the suggestions.
I won't be braiding them myself because I can't be bothered, lol.
Blue is out of the question. I forgot to mention that this motherboard is actually temporary as the mobo/cpu are going to be my folding rig. For the meantime the theme has a lot of blue though and I don't really want to add more.
The board going in is likely to either be the z77x-up7 or the maximus v formula/extreme. Probably the gigabyte because I'm really liking the orange.
