Hey all, i'm new here at OC3D. So i'll start with "Hello!"
I'm currently upgrading my rig, and want to go with the Corsair AX760i PSU. I've got it, got it installed got the cable kit and the 24pin, but one problem is they sent me the AX760/860 one instead of the AX760i/860i one.
I'm not sure if it matters or not, but I don't want to try to install it incase they're not compatible and therefore not being able to send it back as i've opened the box. Could someone clarify whether the AX760/860 24pin cable I have will fit the AX760i, or would I need to specifically get the AX760i/860i 24pin cable?
Thank you, gentlemen!
