Corsair 900D finally finished
l0nestranger
Hi all,
hi all thought I'd post my rig now that I actually finished it after a year of messing around. The specs are Asus X99 deluxe II Motherboard with 5960X @ 4.5ghxz, 2 x Titan x pascal gfx cards in sli, Corsair vengenace 3400 led @ 3440mhz, corsair ax1200i psu, all waterblocks pumps ? res by EK, hardline fittings Bitspower shiny silver. case fans are corsair sp120's x 14.
I modded my 900D by taking out the 5.25" drive cages which then allowed me to fit a 240 rad on the front. In total I have 2 x 240 60mm thick rads & 2 x 480 60mm thick rads for cooling the gpu's & cpu seperatly in the split loop
It is a beautiful build.
I think I am in the minority but the only thing I don't like is the complexity. With water cooling the number of fittings and joints should be kept to a minimum IMHO.
Thanks for the comments, I did try and keep the bends down to a miniimum but was really hard due to the layout of the system & having to cram all of it into the 900D case. don't think I could have made the bends any better than I did.
