Corsair 600T with Dark Rock pro 2
wotevajjjj
Hi,
A friend is building a new pc, but we don't know if the Dark Rock Pro will fit.
In the 600T review on oc3d, there was very little space between the roof fan and the D14. Since the cpu position is rather important, I'll tell you that the motherboard will probably be the msi z77-gd45.
Noctua site says the D14 is 140mm wide and the Dark Rock pro 2 should be 138mm.
Does anyone here know if the msi board has the cpu positioned higher than asus has ?
thanks !
Well my Dark rock advanced fits absolutely fine in my 600T. Since the pro is just slightly longer and not taller i can safely assume that it would fit absolutely fine too
I've searched for some picture off the rampage 3 and the gd45 at the same angle and it looks like the socket on the gd45 is about 2cm lower so all should be good. Took me quite some time to figure out what board was used in the review though, d14 covering everything up..
My friend has the G43 mobo, and his Noctua fit just fine...until he realised his RAM wasn't LP :P
You should be just fine mate.
Since the pro is just slightly longer and not taller i can safely assume that it would fit absolutely fine too.
g.php
