Coolermaster Silent Pro 1000W
i actually think the tx850 is cheaper than the hx750 and if u dont mind hiding cables its prob worth more of a lookin, and the reason i got mines was cause its got 6 pci-e's compared to the hx750's 4 (dont quote me on that) so i can run my 3 cards in here for folding@home
well if i keep ym case that i have now then i will need a modular psu because my case is tiny
how long till u upgrade the rest of ur gear? if modular is needed there prob other qualirt brands out there that might give u better bang for buck
well if possible mate change ur case get a newer one with more flexibility and cable management there's a lot out there like the xigmatek utgard
should do just looked at the case you mentioned and i dont like aesthetics of it really that ide panel is kinda ugly to me.
is the Silverstone Raven any good ?
not too sure but it is expensive tho, best to set a budget for a case otherwise ur gonna be here all night there are so many cases to look at with the vast majority being poo
