positive pressure leads to less dust trapped inside of case. your intake air-flow
(filtered) is more than your exhaust air-flow. thus positive pressure in case.
negative pressure is when the intake air-flow is over-come by the excess
amount of exhaust fan leaving a negative pressure in case. when a negative
pressure is in the case any leak of air from the case (unfiltered) will allow
dust bunnies to multiply inside the case. you will want a 5-15% postive pressure
to keep dust levels low.
to make push/pull work advantagiously, it is best to have similar air-flow specs
between the fans. so mixing fans is not the best idea. if you have one set on the H100, use the same as the second set.
airdeano
airdeano
