wassupdoc
[font="'Arial Narrow"]I'm doing a HTPC / Home cinema build soon, and I've decided on the Lian Li PC-V351B case:[/font]
[/font]
[font="'Arial Narrow"]I'd initially decided on the new low profile version of the dh-14, but after checking, I found out it will not fit
But I was looking at the case and had the idea that due the "slide in" design of the fans and motherboard tray I might just be able to fit a h80 or h60 in one of the front intakes. Do any of you guys know if this will be possible? I'm also open to suggestions for a cooler, but it needs to be 115mm or lower
[/font]
[font="'Arial Narrow"]The Fans in question:[/font]
[/font]
[font="'Arial Narrow"]Thanks guys
[/font]
[/font]
[/font]
