Cooler Compatability
After buying 3 aftermarket coolers i found out that none of them fit a non reference without modding. I stuck with the Gelid Icy Vision Rev.2 and removed the DVI shield so the heatpipe was not interfering.
Temps have gone from:
Stock Cooler
Idle - 43.c
Full Load - 85.c
With fans on auto, although on full load the fans go to max.
Idle - 31.c
Full Load - 55.c
Fans are being controlled via Zalman Fan Mate and is about 40-50% speed.
Used MSI Kombustor to get these results.
Would like to thank QuietPC for allowing me to try out the coolers and determine which ones fit.
I tried The Zalman VF3000n and Zalman VF3000f
Hey I have the same card basically, I have the HD which is the EVGA equivolant I'm wondering how loud is that cooler on the fan speeds you're running, and how hard is it to remove the DVI shielding?
The fans are pretty loud on full blast but @ 40-50 thy're not too bad.
The shielding isn't that hard. I just squeezed the corner with some pliers until it popped out of its clasp then cut across the top of it. Is pretty simple to be honest.
