Coolant Help
BingLingSao
So first time doing my own loop but with the coolant i'm not sure what to get and not sure if i need certain things but these are the options i have for the colour i want which is green,
1) Mayhems Pastel UV White/ http://www.thekoolroom.com/product/mayhems-pastel-uv-white-1lt/
2) Mayhems Emerald Green/ http://www.thekoolroom.com/product/mayhems-emerald-green-15ml/
3) Mayhems Aurora Extinction Green Coolant/ http://www.thekoolroom.com/product/mayhems-aurora-extinction-green-coolant-250ml/
Would I have to mix the UV White with one of the greens to my desire of the colour? am i missing anything? and also i am from Australia so i'm not sure where other places i can get coolants all the help is Appreciated, Thanks
Link to another vendor for your coolant.
http://www.ple.com.au/ViewCategory.aspx?CategoryID=683
I really wouldnt advice on using it long term. Looks bloody unreal though and is really neat with the right res & lighting.
If your want to as I do. Run demin water and a non-glycol anti corrosion mix from an auto store. (Glycol will clog after awhile), its most often than not green in colour and you only need a bit.
get mayhems pastel white and add the emerald green dye
or
mayhems X1 clear and add the emerald dye.
If you want to go for an opaque green coolant, then I would do with the pastel white concentrate as well, and then add the green dye in yourself to get it to the colour you want.
Not sure what kind of green you're going for, but here's a snapshot of the mint green pastel coolant in my rig:
If you want a more transparent coolant, you could also just add the dye to DI water to get something like this (what my coolant used to look like) :
hope these pictures give you a rough idea of what you can get from mayhem's coolants. simply the best! :)
