Confused PCIe Slot
Vipermk2
As far as I knew your graphics card should be plugged into the first PCIe slot, however due to my cooler getting a little too close to the Card I have moved it down one into the PCIe 3.0 x8_2 slot. (which I initially thought was PCIe 3.0 x16_2 slot)
Am I totally misunderstanding how Graphics cards work but shouldn't it be running slower in the PCIe 3.0 x8_2 slot, or does it only become a x8 slot when the top slot is already already populated?
TBH it's all very bloody confusing. When I used the primary slot in both of my X99 boards my GPU ran at X8. When I moved it down to the middle slot on my X99 SLi Plus it runs at X16.
Download GPUZ, then click the ? next to where it lists your PCIE bus speed on the GPU. It will open a render test, simply watch what your GPU bandwidth shows with that test running.
It reads @x8 1.1 before the render. It must be fine as I'm getting the same frame rates as TTL did on his reviews of the card, if not a touch more.
theres a very marginal between x16 and x8 as far as performance goes. But if you want every bit of performance from it pop it in the 4th slot which read pci-e 3.0 x16/x8 3 slot. I looked at the back of the board and it is wired for x16
