M&P,
Mad props for you educating me, I really appreciate the time you've taken to help me make the right choices. I'm not really sure of what vendors are available in the USofA but I've been browsing via FrozenCPU. They're prices seem okay if not a little high. If you have any other vendors, lemme know!
I've already decided to get the XSPC Raystorm CPU block (I'm still deciding if I wanna replace the TIM with MX-4 on my CPU >.< haha). Not sure if the +$30 is worth it for the Chrome or Copper variations. The regular one is ~$60 and I guess is acetal?.
I don't have the front drive space bays available for a reservoir since I'm going to use a Aerocool Touch 2000 to control my fans except for one if I decide not to use a DVD drive and get an external one, but you've recommended to get a larger reservoir so a single slot res is too small. Not sure if there is a res that would fit in the drive cage so I'll have to Google around. But if I could I was looking at an Alphacool single bay res or something similar. If not I'll get a tube res like this and mount it in between the drive bays and the motherboard (then I'd just have to figure the biggest size that would fit). Both reservoir options also come with a pump combo here (single bay) and here (there's two bitspower versions) respectively.
For pumps only, I've only managed to sort of browse these ones, but I don't know how well they would mount in my case (variable speed pumps seem cool b/c I can set them at mid-range for the silence but also be able to crank them up if i ever needed to):
EK D5 X-Top Acetal Pump Top CSQ w/ Alphacool VPP655 Variable Speed Pump Installed
Swiftech MCP350™ 12v Water Pump (Native 3/8") (92.4 GPH)
Swiftech MCP35X 12v PWM Controlled Water Pump - White
Swiftech MCP655 Variable Speed 12v Water Pump w/ G1/4 Thread Ports (Perfectly Tapped)
As for my fans, right now I want to have 3x140mm fans mounted under the plastic grill which is on top of my rig. Would it be that detrimental to have it mounted there rather than have it actually mounted to my radiator then mounted internally? Is there a huge difference in performance between a 360x60mm (like the Alphacool NexXxoS UT60 360x60mm) vs a 420x60mm radiator? I'm assuming it cools better so my next question would be what is the difference between the Phobya G-Changer 420x60mm and the Alphacool NexXxoS UT60 420x60mm Copper raditaor? Their prices are about equivalent @ ~$105-110.
Not sure what size tubing I should get? I think I want to use compression fittings for the ease and clean look they give. Also not sure if I want to dye my water or get a colored tubing. I think a clear tubing with color will allow me to see bubbles and whatnot. What other accessories and fittings should I get like barbs or adapters? Something about a kill coil?
I thought I read somewhere I should mix Acetal parts of any kind with other certain parts/fluid?
Random thought, I want to mod the bottom of the front intake grill, I noticed that it's not covered with a filter. Any suggestions or am I just being a dust worrywart?
That's all I've got for now. Will hopefully get a GTX 670 upgrade (still deciding on GPU) which I will want to XFire/SLi and watercool (for the silence and looks) in the future. Thanks again!
Ah, I see. Haha. Would it really make that much of a difference if say the fans were identical in cfm and dbs? The only upgrade from a 140 down to a 120 was if i got something more high performance/quiet, right?
Parts, is what I wanted to say. You missunderstood me there, you said that you have only 140mm fans atm, then I said that should work even though the rad is 120mm but I'd replace the 140s with 120s asap.
