CoD4 server PB problems
Shame this has happened but as Panzer said, it was just a matter of time. I have not been able to get on the server for 26 days or so, (since the hacker banned MY IP)
I hope it gets sorted, and its nice to finally see some of the regulars from the server posting here as well.
I have jsut upgraded to Win 7 and have yet to install COD4 (todays task) so will see what it says when I try to get on later.
name='Fikor' said:
well my call of duty folder is on hard disk E not on the regular C.
Do i have to install it in the CoD4 folder? I have it installed on C but i can't copy the files from C to E where the pb folder is. oh and one more thing the file i download has a folder also named pb.so if i install it to the CoD 4 i will overwrite it the original punkbuster.
Plz help me how u did ut. Thanks :D
while installing it will ask u for path to COD4 main folder........ give ur location properly i.e. ur COD4\pb
start COD4mp....... turn ON PB........ join server.......
yes installed it properly this time. I turned on PB and after 5 minutes of playing the messages started coming out :(
I installed v1.3..... then v1.5....... v1.6....... then again 1.5....... after which it worked.....:D
I dont know which combo will work for others...... best to keep trying and make it work....... coz PB will hav to be turned ON again....... too many cheaters..... I think even older cheats may be working with PB down....... cheaters r having a ball......
I've started a message rotation on the server telling people to rename their PB folder if they want to play on there. Also I've managed to free up an IP address so as soon as I can find a way to bind the existing server to just one IP address I'll get to work on the other one.
New server up and running (hopefully) on 212.69.36.86 with PB enabled and legit exe files :)
Lemme know how ya get on :)
Stupid punkbuster... 'Banned' another of the servers I regularly play on too, causing massive unplayable lag.
Wtf. Just wtf.
212.69.36.86 is OFFLINE as of now...... let us know when it ON even the port no....... yes and make it legit...... Thx Jim:)
Wtf. Just wtf.
Just disable punkbuster(multiplayer options)..... then join server....
Its on now, and finally I can get on an OC3D server bit empty though, port no is 28960 and I recognise the IP. ;)
The game settings need tweaking time limit etc.
Yeah thats usually the case so spread the word guys :)
I also feel that alot of people are into hardcore mode and other match types now as well, the game has been out a while.
