Sup guys,
So i've been thinking positive case pressure would be an easy way to minimise dust in my rig, so the simple solution for that seems to be to switch the rear 140mm to an intake (with a filter of course). That would mean i'd have the 2x120mm taking in air from the front, the 140mm from the rear, and 2x120mm expelling it through the roof.
My only question is, would that interfere with the performance of my CPU cooler, which is obviously blowing air towards that rear fan? Or would the difference be fairly negligible?
Cheers all
Cheers all
