Permafrost
Compo Whore
hi guys and girls, as some of you know i'm doing a case change from a 750D back to a switch 810 and need a few tips when it comes to cleaning out the loop, the coolant i'm using atm is mayhems pastel ice white.
now what i need to know is deionized water or distilled water for cleaning?
and what clear water to use for the loop as i might add a red dye in later or leave it as it is??
the theme ii'm thinking of going is red and white or just leaving it all white.
if there is anything anyone can think of that will help please let me know
I'm not a pro at watercooling and I would appreciate any tips or help
the loop is:
250mm x 50mm tube res
18w DDC pump
GTX 780 waterblock (not sure what one i'm getting)
EK XTX 360mm rad
Heatkiller V3 in white (might change it....)
EK XTX 240mm rad
the loop is:
18w DDC pump
EK XTX 360mm rad
EK XTX 240mm rad
