Cleaning gone...sort of wrong
Asen
Hi there, today I was cleaning my Asus GTX 970 Strix card and I had to remove the fans and shroud in order to clean the aluminium fins. My problem is very simple: the shroud and fans are attached to the heatsink with a bracket system, so non screws, but I have to mount the brackets to the shroud in order to make everything stand in one piece. The brackets have 2 screws each and I don't know why, but I was only able to mount 3 screws in total, but everything is firm.
The card works fine, even though I had to force it quite a bit in order to put it back together. My question if anyone can send me a detail procedure with pictures how to assemble and dissasemble the card correctly. I hope the problematics are very clear.
