changing my fans
gampla
im looking to replace all my fans in my current build for some new/better fans atm im running
2 sickleflows
2 sp120l
1 120 spectre
1 230 spectre
and ideas and no noctua and which 230 fan or should i go fo 2 120
However, take a look at Coolingtechnique.com ( it's in italian, but the important things are fan videos... and you can still translate it with your browser )
Do you need case fans or radiator/heatsink fans? Budget?
sp120l stock with corasir aio
Hydro Series H105 provides extreme CPU cooling performance. The 240mm top-mounted high-capacity radiator is paired with high-performance SP120L fans for the powerful heat dissipation
I would offer you BeQuiet! fans if you don't want to have a LED-on them. If you want some LED to go for Corsair or Enermax or maybe BitFenix ones.
